Hi!
I want to install something on my esp32 but it dosn’t work.
Maybe someone finds an error…
This is the error:
INFO ESPHome 2025.4.1
INFO Reading configuration /config/esphome/esphome-web-6912f8.yaml...
Failed config
ota.unknown: [source /config/esphome/esphome-web-6912f8.yaml:21]
'ota' requires a 'platform' key but it was not specified.
platfrom: esp32
password: programmieren123!
And this the code
esphome:
friendly_name: Bewaesserung_1
min_version: 2024.11.0
name_add_mac_suffix: false
esp32:
board: esp32dev
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "34f61ac3ff908fad4c26acbbce7d30e5"
ota:
platfrom: esp32
password: "programmieren123!" # Passwort für OTA-Updates
wifi:
ssid: ****************
password: ***************
ap:
ssid: "Bewaesserung_1 Fallback Hotspot"
password: "***************"
captive_portal:
# Define time component
time:
- platform: homeassistant
# Define switches (Relays)
switch:
- platform: gpio
pin: D2
restore_mode: ALWAYS_OFF
on_turn_on:
- delay: 20min
- switch.turn_off: rasen_sprinkler_eingangsbereich
- platform: gpio
pin: D4
on_turn_on:
- delay: 30min
- switch.turn_off: rasen_sprinkler_hinten_rechts
- platform: gpio
pin: D16
on_turn_on:
- delay: 30min
- switch.turn_off: rasen_sprinkler_hinten_links
- platform: gpio
pin: D17
on_turn_on:
- delay: 20min
- switch.turn_off: gemuese_sprinkler_hochbeet
- platform: gpio
pin: D5
on_turn_on:
- delay: 40min
- switch.turn_off: thujen_tropfschlauch
- platform: gpio
pin: D18
on_turn_on:
- delay: 40min
- switch.turn_off: weg_tropfschlauch
# Define weekly schedule for valves (optimized with OR conditions)
interval:
- interval: 1s
then:
- if:
condition:
and:
conditions:
- time.weekday: MONDAY
- time.weekday: WEDNESDAY
- time.weekday: SATURDAY
- time.hour == 4
- time.minute == 00
then:
- switch.turn_on: rasen_sprinkler_eingangsbereich
- if:
condition:
and:
conditions:
- time.hour == 4
- time.minute == 30
then:
- switch.turn_on: rasen_sprinkler_hinten_rechts
- if:
condition:
and:
conditions:
- time.hour == 5
- time.minute == 00
then:
- switch.turn_on: rasen_sprinkler_hinten_links
- if:
condition:
and:
conditions:
- time.hour == 5
- time.minute == 30
then:
- switch.turn_on: gemuese_sprinkler_hochbeet
- if:
condition:
and:
conditions:
- time.hour == 6
- time.minute == 00
then:
- switch.turn_on: thujen_tropfschlauch
- if:
condition:
and:
conditions:
- time.hour == 6
- time.minute == 30
then:
- switch.turn_on: weg_tropfschlauch
