Hi all,
I am trying to install the supervised version on Debian 11. I followed the instructions on “Installing Home Assistant Supervised on Debian 11”. When I try to install it with dpkg -i homeassistan-supervised.deb
I get the following error.
"Get "https://registry-1.docker.io/v2": dial tcp: lookup registry-1.docker.io on [::1]:53: read udp [::1}:50116-> [::1]: read: connection refused
If I try hello-world it works fine. I also tried to add dns 1.1.1.1 and 8.8.8.8 that also didn’t work. Anybody an idea what I could do? Thanks in advance!
Marijn
