I had a spare RPI laying around and wanted to test this.
No luck though. The installation seems to run fine until this:
src/c/_cffi_backend.c:2:10: fatal error: Python.h: No such file or directory
2 | #include <Python.h>
compilation terminated.
error: command '/usr/bin/arm-linux-gnueabihf-gcc' failed with exit code 1
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for cffi
Failed to build cffi
ERROR: Failed to build installable wheels for some pyproject.toml based projects (cffi)
So I’m missing a header file; the question is which one and where to get it from.
