Hi.
There is a new odroid on the market, the C5
Would be nice to see it will be supported for HAOS.
I will buy one to figure out if the HA image of the C4 works on the C5.
Keep you posted.
Hi.
Keep you posted.
Unfortunatly it doesnt work with the HAos image of C4
You could go for HA Container (Installation - Home Assistant → ODROID - Home Assistant)
There are no addons with that method.
But i can give it a try.
I guess that’s the only option you have right now…
I am also looking into buying this device, it seems great to run HA with its eMMC module instead of SD card. Would anybody be able to generate an image for this for HAOS or give me some guidance on how to compile it myself? Would be greatly appreciated!
I can confirm. I also tried to move the MMC card from Odroid-C4 to Odroid-C5 with HAOS. Odroid-C5 did not start, no boot.
tried also other images, but none of them work. Installed ubuntu and then HA but i need also the add-ons. Hope for the C5 image ![]()
