Hello all
New to Hass.io but like what I see. Step learning curve with me not coming from a programming background. I have installed the HASS.io via Virtualbox using the VHDX file on the Hass.io website. HA comes up fine and works as per normal.
I have been looking at HACS and in the install guide I need to copy the HACS folder into a folder. Now this has stopped me in my tracks. Can anyone help with the below
- As this is a VHDX install, can I still access the Linux command line?
- SAMBA fails to work? (interface error, what is the file path)
- Can you upload the HACS file + the file content via the Configurator Add-on. I can see you can do a single file but not a folder
- can hass.io be installed on Ubuntu or in a docker container
Sorry for all the questions and hopefully these are simple questions
TIA
