Install issues with Synology DS415Play
First post… be gentle :slight_smile:
I’ve installed python 3.5.1 and no pip
I copied get-ipi.py to the /volume1/@appstore/py3k/usr/local/bin folder
but when I run
python3 get-pip.py
I get the following…
Collecting pip
Using cached pip-8.1.2-py2.py3-none-any.whl
Collecting setuptools
Using cached setuptools-28.6.0-py2.py3-none-any.whl
Collecting wheel
Using cached wheel-0.29.0-py2.py3-none-any.whl
Installing collected packages: pip, setuptools, wheel
Exception:
File “/tmp/tmp8_lmw5tx/pip.zip/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/tmp/tmp8_lmw5tx/pip.zip/pip/commands/install.py”, line 317, in run
prefix=options.prefix_path,
File “/tmp/tmp8_lmw5tx/pip.zip/pip/req/req_set.py”, line 742, in install
**kwargs
File “/tmp/tmp8_lmw5tx/pip.zip/pip/req/req_install.py”, line 831, in install
self.move_wheel_files(self.source_dir, root=root, prefix=prefix)
File “/tmp/tmp8_lmw5tx/pip.zip/pip/req/req_install.py”, line 1032, in move_wheel_files
isolated=self.isolated,
File “/tmp/tmp8_lmw5tx/pip.zip/pip/wheel.py”, line 346, in move_wheel_files
clobber(source, lib_dir, True)
File “/tmp/tmp8_lmw5tx/pip.zip/pip/wheel.py”, line 317, in clobber
ensure_dir(destdir)
File “/tmp/tmp8_lmw5tx/pip.zip/pip/utils/init.py”, line 83, in ensure_dir
os.makedirs(path)
File “/volume1/@appstore/py3k/usr/local/lib/python3.5/os.py”, line 241, in makedirs
mkdir(name, mode)
PermissionError: [Errno 13] Permission denied: ‘/volume1/@appstore/py3k/usr/local/lib/python3.5/site-packages/pip-8.1.2.dist-info’
DS415Play is running DSM 6.0.2-8451 Update 2
any help appreciated…
-f
Didn’t try direct install on synology.
Performed install via Docker. I’m liking this a lot better from security perspective(not that I know much about that)
Like it so much I moved all my services/application into docker containers
