Install Keeps Failing
Hi new here, I try to add my M5StickC2 to ESPHome but every time the logs ether quietly stop or show command terminated.
this is what i get
INFO ESPHome 2024.6.6
INFO Reading configuration /config/esphome/esphome-web-b83e8c.yaml…
INFO Generating C++ source…
INFO Compiling app…
Processing esphome-web-b83e8c (board: esp32dev; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
  • toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
    Dependency Graph
    |-- AsyncTCP-esphome @ 2.1.3
    |-- WiFi @ 2.0.0
    |-- FS @ 2.0.0
    |-- Update @ 2.0.0
    |-- ESPAsyncWebServer-esphome @ 3.2.2
    |-- DNSServer @ 2.0.0
    |-- ESPmDNS @ 2.0.0
    |-- ArduinoJson @ 6.18.5
    |-- Improv @ 1.2.3
    Linking .pioenvs/esphome-web-b83e8c/firmware.elf
Thanks for the help!
What machine are you running esphome on? Looks like it is running out of RAM.
a VM on my Unraid server, i thought i had tried that but turns out i didn’t, and it worked.
Thanks!
