Install mqtt
I tries to install mqtt but I get this error
[2025-04-03 18:30:03] error: zh:ezsp:uart: → Error: Error: {sequence:-1} after 10000ms
[2025-04-03 18:30:03] error: zh:ezsp:ezsp: Connection attempt 1 error: Error: Failure to connect
[2025-04-03 18:30:18] error: zh:ezsp:uart: → Error: Error: {sequence:-1} after 10000ms
[2025-04-03 18:30:18] error: zh:ezsp:ezsp: Connection attempt 2 error: Error: Failure to connect
Seems like you try to install Zigbee2mqtt. And the error seems to point to the fact that ZHA is still running.
I disabled the zha , or I think I did
Show your Zigbee2mqtt configuration.yaml
