Hello! I’m new to linux and home assistant, but I have small experience with php web sites coding.
Is it possible to install php web server with MySQL in parallel to HA with ability to interact with each other by REST API?
Do i need to install php web server to virtualenv?
What would be configs for HA web server (to listen 8123 port) and for php web server (to listen 80 port)?
My current HA running on Orange pi Zero in virtualenv + mosquitto.
Hi! No, i didn’t find an anwser to my question, but have some ideas. I think i will try first of all install apache web server with mysql and php. Then I will install HA and configure apache proxy for Home Assistant. It is just an idea. Don’t know if this will work.
I think, since you aren’t running Hass.io, you can just run them in parallel, just make sure to use different ports. For me though, I need to find out how to run a php server using docker on hassio
