I wanted to install the extension “Stateful Scenes” via HACS. I installed it in HACS without an error message. Then I tried to install it via the extensions (integration). When installing, the following error occurs.
Unfortunately, I can’t quite figure it out anymore, Google can’t find a solution, and the forum here can’t find anything either (I’ve searched several times).
When installing the integration, the error occurs:
Invalid scenes file
The file is present in the file system and is currently empty.
Nothing has been changed in the standard configuration.
The file is integrated in the “Configuration.yaml”.
Does anyone know the solution to the problem?
EDIT: Problem solved. After creating a scene it was easy to set up.
