I use Home Assistant on Docker in a Raspberry Pi 4.
I did the update 2021.11.4 and since then I am stuck with the “Preparation page” and nothing works anymore.
su log shows :
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2021.11.4.
[supervisor.docker.interface] Can’t install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2021.11.4: 500 Server Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2021.11.4/json: Internal Server Error (“layer does not exist”)
Is there something to do? I hope my config will not be lost.
Thank you!
