Installation does not complete on raspberry pi
Since yesterday I’ve been trying to install Home Assistant on my Raspberry Pi 4, but I’m always stuck on the “This may take up to 20 minutes” page.
In the logs you can see that the following task is failing:
I’ve tried rewriting the image, but the same error keeps happening.
Can anyone help me with this?
It looks like the RPi can’t get the image needed from the internet to complete the installation. Check you network connection.
The network connection is perfect, the raspberry is connected via ethernet cable to the modem…
Also perfect enough that DNS is fully operational and that you did not block access to github with a pihole, Aduard or similar?
