Installation HA CM5 Yellow
Hi Community!
New to HA. Ordered HA yellow + CM5. Did the manual installation. When i first try to install. I am runing rpiboot and the boot gets installed on my pc (it says installed status 0,) I am not sure if it is installed on my PC or HA.
The Solid Red light never goes away. I double checked USB cable and JP1 jumper is set to USB as well.
Please help. I dont know how to check if the hardware is defective, if CM module or HA board is defective.
Thx much for your help!!
Do you have a solution?
Hi, I had to enable the installation of raspberry through manual process going in to the installed rpiboot. thx a lot community!
