I run homeassistant under proxmox. In the documentaion to 2025.5 I found the integration ntfy (ntfy.sh) for simple notifications. I use my own DNS server (pihole) with my local domain “.local”.
I installed ntfy as a service in proxmox with a self signed certificate. Startup went okay. I can run “ntfy publish homeassistant test” and “curl -d ‘test’ ntfy.local/homeassistant” commands in proxmox and get the push notification on the ntfy smartphone app.
In the homeassistent terminal “curl -d ‘test’ ntfy.local/homeassistant” also works without problems, so homeassistant has no problems reaching the server and DNS resolution works.
Now I wanted to install the ntfy integration.
I started wit + Add integration and found ntfy to install. I got a menu “ntfy” and " Set up ntfy push notification service" requesting me to enter the service URL, which was preconfigured with “https://ntfy.sh” (the public server).
Instead of “https://ntfy.sh” I entered my own server https “ntfy.local” and clicked “verify SSL certificate” off. I also tried pure http with http “ntfy.local”.
In both cases the installation failed with “Failed to connect”.
When I tried in my desperation with http “10.0.0.170” I got success. ntfy is installed with “10.0.0.170” and “No devices or entities”. It also worked with https “10.0.0.170”, verify SSL certificate set off.
Why does it not accept ntfy.local ?
Can I use it without problems with http and IP address instead of DNS name ?
in the configuraion.yaml I use my own address or do I have to use the IP address ?
# ntfy notifications
notify:
- name: "ntfy hackerd"
platform: ntfy
url: "https://ntfy.local" # this or "https://10.0.0.170" ? ?
# token: not needed
topic: "homeassistant"
