Hello!
when trying to install the Tasmota integration on HA i am getting following error message:
Unable to set up dependencies of tasmota. Setup failed for dependencies: mqtt
following stack trace:
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 118, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 127, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 129, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 136, in post
return await super().post(request)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 60, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 69, in post
result = await self._flow_mgr.async_init(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 119, in async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 541, in async_create_flow
await async_process_deps_reqs(self.hass, self._hass_config, integration)
File "/usr/src/homeassistant/homeassistant/setup.py", line 339, in async_process_deps_reqs
raise HomeAssistantError("Could not set up all dependencies.")
homeassistant.exceptions.HomeAssistantError: Could not set up all dependencies.
Version used: 2021.2.3 with Home Assistant OS
Mosquitto is already installed and apparantly properly operational:
1613612416: New connection from 192.168.1.226 on port 1883.
[INFO] found tasmota-mqtt on Home Assistant
1613612416: New client connected from 192.168.1.226 as Büro (p2, c1, k30, u'tasmota-mqtt').
When trying to install the Tasmota integration the loading screen just pops up for a fraction of a second and then vanishes. No clue what to do anymore…
Thanks!
