Hi everyone.
Not entire sure where to start, but I bought a ZBT-2 in order to move over to that from the Yellows internal radio.
Using the internal radio everything worked with no issue in Z2M, but after installing ZBT-2 and pointing Z2M towards that more or less all the lights in house stopped working. My lights from IKEA have been fine for a day after reconnecting them (they’ve stopped working again now) and my Hue lights have just been fully unresponsive since shifting.
Z2M reports the following:
Show only
Filter by text
Highlight only
Logs limit
Log level config
[27/01/2026, 20.21.33] z2m: Publish 'set' 'brightness' to 'Loftslampe (TV stuen)' failed: 'Error: ZCL command 0x001788010de8f3b3/11 genLevelCtrl.moveToLevelWithOnOff({"level":43,"transtime":0,"optionsMask":0,"optionsOverride":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for '6955'.)'
[27/01/2026, 20.22.34] z2m: Publish 'set' 'state' to 'Spejl (badeværelse)' failed: 'Error: ZCL command 0x001788010bf290d2/11 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for '59921'.)'
[27/01/2026, 20.22.34] z2m: Publish 'set' 'state' to 'Lysekrone 3 (entre)' failed: 'Error: ZCL command 0xb4e3f9fffe0c23e4/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for '5607'.)'
[27/01/2026, 20.22.34] z2m: Publish 'set' 'state' to 'Lysekrone 1 (entre)' failed: 'Error: ZCL command 0xb4e3f9fffeacd6e6/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for '33530'.)'
[27/01/2026, 20.22.34] z2m: Publish 'set' 'state' to 'Lysekrone 2 (entre)' failed: 'Error: ZCL command 0xb4e3f9fffe0c0984/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for '33479'.)'
I am far out of my depth on this, so I have someone on here knows what is going on, or if other pepole have had similiar issue.
