So, after some digging the display shows the result!!
At first, Freenove sent me a Schematic of the Mini TV, so i could extract the right pinout.
After that i had to set the pin vor VDD to high on boot and this is the resulting yaml:
substitutions:
device_name: "freenove-esp32-mini-tv"
esphome:
friendly_name: "Freenove ESP32 Mini TV"
on_boot:
- priority: 200
then:
- output.turn_on: output_vdd
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: VERBOSE
baud_rate: 0 #no hardware serial connected to USB - unless using the internal programming header
logs:
#lvgl.component: VERBOSE
light.component: ERROR
light.output: ERROR
number.component: ERROR
ledc.output: ERROR
template.number: ERROR
select:
- platform: logger
# Enable Home Assistant API
api:
encryption:
key: "tZIPmmDJTeSM1yGv1iAO5Kr+P3pZ8H0zemll16veeVU="
ota:
- platform: esphome
wifi:
ssid: !secret wifi_ssid
ap:
ssid: ${device_name}
captive_portal:
# external_components:
# - source: github://clydebarrow/esphome@lvgl
# components: [ lvgl ]
# Define a PWM output on the ESP32
output:
- platform: ledc
pin: GPIO19 #GPIO05
inverted: True
- platform: gpio
pin: GPIO21
inverted: True
# Define a monochromatic, dimmable light for the backlight
light:
- platform: monochromatic
output: backlight_pwm
name: "Display Backlight"
restore_mode: ALWAYS_ON
on_turn_on:
- light.turn_on:
brightness: 100% # Set initial brightness to 100% on power up
esp32_touch:
setup_mode: False
binary_sensor:
- platform: esp32_touch
name: "ESP32 Touch Pad"
pin: GPIO32
threshold: 1400
spi:
clk_pin: GPIO14
mosi_pin: GPIO13
interface: hardware
color:
- id: my_red
red: 100%
green: 0%
blue: 0%
- id: my_orange
red: 100%
green: 50%
blue: 0%
- id: my_yellow
red: 100%
green: 100%
blue: 0%
- id: my_green
red: 0%
green: 100%
blue: 0%
- id: my_blue
red: 0%
green: 0%
blue: 100%
- id: my_teal
red: 0%
green: 100%
blue: 100%
- id: my_gray
red: 70%
green: 70%
blue: 70%
- id: my_white
red: 100%
green: 100%
blue: 100%
- id: my_black
red: 0%
green: 0%
blue: 0%
font:
- file: "gfonts://Roboto"
display:
- platform: ili9xxx
model: st7789v
spi_id: spihwd
data_rate: 20MHz #oringal device uses 20mhz - 40 is default and works - does not work at 80mhz
cs_pin: GPIO15 #CS pin is connected to gnd I believe
dc_pin: GPIO02
#reset_pin: GPIO04
#spi_mode: MODE3 #since no cs pin default is mode0
dimensions:
width: 240
height: 240
offset_height: 0
offset_width: 0
invert_colors: true
color_palette: 8BIT
#update_interval: never
#auto_clear_enabled: false
lambda: |-
it.rectangle(0, 0, it.get_width(), it.get_height(), id(my_blue));
it.rectangle(0, 20, it.get_width(), it.get_height(), id(my_blue)); // header bar
//it.print(5, 5, id(font_12), id(my_yellow), TextAlign::TOP_LEFT, "ESPHome");
it.strftime(5, 5, id(font_12), id(my_yellow), TextAlign::TOP_LEFT, "%H:%M:%S", id(time_comp).now());
it.print((it.get_width() / 2), (240 / 6.5) * 1 - 8, id(font_12), id(my_yellow), TextAlign::CENTER, "Testing");
it.printf((it.get_width() / 2), (240 / 6.5) * 1 + 9, id(font_24), id(my_yellow), TextAlign::CENTER, "%.2fC", 0.000);
it.line(0, (240 / 6.5) * 1 + 18, it.get_width(), (240 / 6.5) * 1 + 18, id(my_blue));
it.print((it.get_width() / 2), (240 / 6.5) * 2 - 8, id(font_12), id(my_green), TextAlign::CENTER, "Testing 1");
it.printf((it.get_width() / 2), (240 / 6.5) * 2 + 9, id(font_24), id(my_green), TextAlign::CENTER, "%.2fC", "1.111");
it.line(0, (240 / 6.5) * 2 + 18, it.get_width(), (240 / 6.5) * 2 + 18, id(my_blue));
it.print((it.get_width() / 2), (240 / 6.5) * 3 - 8, id(font_12), id(my_orange), TextAlign::CENTER, "Testing 2");
it.printf((it.get_width() / 2), (240 / 6.5) * 3 + 9, id(font_24), id(my_orange), TextAlign::CENTER, "%.2fC", 2.222);
it.line(0, (240 / 6.5) * 3 + 18, it.get_width(), (240 / 6.5) * 3 + 18, id(my_blue));
it.print((it.get_width() / 2), (240 / 6.5) * 4 - 8, id(font_12), id(my_gray), TextAlign::CENTER, "Testing 3");
it.printf((it.get_width() / 2), (240 / 6.5) * 4 + 9, id(font_24), id(my_gray), TextAlign::CENTER, "%.2fC", "3.333");
it.line(0, (240 / 6.5) * 4 + 18, it.get_width(), (240 / 6.5) * 4 + 18, id(my_blue));
it.print((it.get_width() / 2), (240 / 6.5) * 5 - 8, id(font_12), id(my_teal), TextAlign::CENTER, "Testing 4");
it.printf((it.get_width() / 2), (240 / 6.5) * 5 + 9, id(font_24), id(my_teal), TextAlign::CENTER, "%.2fC", 4.444);
it.line(0, (240 / 6.5) * 5 + 18, it.get_width(), (240 / 6.5) * 5 + 18, id(my_blue));
it.print((it.get_width() / 2), (240 / 6.5) * 6 - 8, id(font_12), id(my_red), TextAlign::CENTER, "Testing 5");
it.printf((it.get_width() / 2), (240 / 6.5) * 6 + 9, id(font_24), id(my_red), TextAlign::CENTER, "%.2fC", 5.555);
time:
- platform: sntp
timezone: "Europe/Berlin"
