Installing ESPhome on GEEKMAGIC Smart Weather Clock (smalltv/pro)
That did not work, i added the firmware from ESPHome and called it firmware.ota.bin and it did not flash the new firmware i created
Okay so you shouldn’t be renaming a file. When you compile through the command line one of the files produced is named firmware.ota.bin. That is the one I flashed using the factory web interface, then it worked.
Either way, if you can figure out the pinout of those pins on the left side of your picture you should be able to flash via serial the normal way.
I received this version also and have it working—sort of. For a start could not get the code to work for 240x240, had to reduce it to 235 x 235.
Flashed the CS-32E as a ESP32
My code for display
Display:
  - platform: ili9xxx
    model: st7789v
    spi_id: spihwd
    data_rate: 40MHz #oringal device uses 20mhz - 40 is default and works - does not work at 80mhz
    #cs_pin: GPIO03 #CS pin is connected to gnd I believe
    dc_pin: GPIO02
    reset_pin: GPIO04
    spi_mode: MODE3   #since no cs pin default is mode0
    dimensions:
      width: 235
      height: 235
      offset_height: 0
      offset_width: 0
    invert_colors: true
So i am using ESPHome through Home Assistant and am not sure what i need flash to the device. @Dingo Would you be willing to post the whole yaml you used for yours?
Intially I used Home Assistant - ESPhomebuilder, create new device. I will post the code i used…I still have some issues with sizing but trying to fix these, but its a start
esphome:
  friendly_name: EnergyTV
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  level: VERBOSE
  logs:
    #lvgl.component: VERBOSE
    light.component: ERROR
    light.output: ERROR
    number.component: ERROR
    ledc.output: ERROR
    template.number: ERROR
  baud_rate: 0 #no hardware serial connected to USB - unless using the internal programming header
# Enable Home Assistant API
api:
  encryption:
    key: "mine"
ota:
  - platform: esphome
    password: "mine"
wifi:
  ssid: IOT
  password: mine
  ap:
    ssid: "Geekmagic-Hilo Fallback Hotspot"
    password: "mine"
captive_portal:
external_components:
 - source: github://clydebarrow/esphome@lvgl
   components: [ lvgl ]
# Define a PWM output on the ESP32
output:
  - platform: ledc
    pin: GPIO25
    inverted: True
# Define a monochromatic, dimmable light for the backlight
light:
  - platform: monochromatic
    output: backlight_pwm
    name: "Display Backlight"
    restore_mode: ALWAYS_ON
esp32_touch:
 # setup_mode: true
  - platform: homeassistant
    entity_id: sensor.shellyem_98cdac1f0b5f_channel_1_voltage
    internal: true
    state_class: measurement
    unit_of_measurement: Volts
    entity_id: sensor.shellyem_98cdac1f0b5f_channel_1_power
    internal: true
    unit_of_measurement: Watts
    entity_id: sensor.shellyem_98cdac1f0b5f_channel_2_power
    internal: true
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
  interface: hardware
color:
  - id: my_red
    red: 100%
    green: 0%
    blue: 0%
  - id: my_orange
    red: 100%
    green: 50%
    blue: 0%
  - id: my_yellow
    red: 100%
    green: 100%
    blue: 0%
  - id: my_green
    red: 0%
    green: 100%
    blue: 0%
  - id: my_blue
    red: 0%
    green: 0%
    blue: 100%
  - id: my_teal
    red: 0%
    green: 100%
    blue: 100%
  - id: my_gray
    red: 70%
    green: 70%
    blue: 70%
  - id: my_white
    red: 100%
    green: 100%
    blue: 100%
  - id: my_black
    red: 0%
    green: 0%
    blue: 0%
font:
  - file: "gfonts://Roboto"
display:
  - platform: ili9xxx
    model: st7789v
    spi_id: spihwd
    dc_pin: GPIO02
    reset_pin: GPIO04
    dimensions:
      width: 235
      height: 235
      offset_height: 0
      offset_width: 0
    invert_colors: true
    #update_interval: never
    #auto_clear_enabled: false
    lambda: |-
      it.rectangle(0,  0, it.get_width(), it.get_height(), id(my_blue));
      it.rectangle(0, 20, it.get_width(), it.get_height(), id(my_blue));   // header bar
      //it.print(5, 5, id(font_12), id(my_yellow), TextAlign::TOP_LEFT, "ESPHome");
      it.strftime(5, 5, id(font_12), id(my_yellow), TextAlign::TOP_LEFT, "%H:%M:%S", id(time_comp).now());
      it.print((it.get_width() / 2), (240 / 5.5) * 1 - 8, id(font_20), id(my_yellow), TextAlign::CENTER, "Voltage");
      it.printf((it.get_width() / 2), (240 / 4) * 1 + 9, id(font_36), id(my_yellow), TextAlign::CENTER, "%.1fVac",id(voltage).state);
      it.print((it.get_width() / 2), (240 / 4.5) * 2 - 8, id(font_20), id(my_green), TextAlign::CENTER, "Grid Power");
      it.printf((it.get_width() / 2), (240 / 4) * 2 + 9, id(font_36), id(my_green), TextAlign::CENTER, "%.1fW",id(power).state);
      it.print((it.get_width() / 2), (240 / 4.2) * 3 - 8, id(font_20), id(my_orange), TextAlign::CENTER, "Solar Power");
      it.printf((it.get_width() / 2), (240 / 4) * 3 + 9, id(font_36), id(my_orange), TextAlign::CENTER, "%.1fW",id(solarpower).state);
time:
  - platform: sntp
That worked!!! It is giving me errors when it says mine??? im just kidding. Thanks again @Dingo
I was able to get everything working on a PRO variant (ESP32E) using LVGL and no external ESPHome components. I’m using ESPHome 2025.3.2.
The full 240x240 resolution is also working.
This example boots up with the ESPHome logo and a spinner (taken from the ESPHome LVGL documentation) and then shows a clock with date and time (taken from ESPHome documentation).
Seems to work very well! Thanks for everyone’s help.
esphome:
  friendly_name: SmallTV Pro
  min_version: 2024.11.0
  name_add_mac_suffix: false
  on_boot:
    - delay: 5s
    - lvgl.widget.hide: boot_screen
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  baud_rate: 0
api:
ota:
  - platform: esphome
wifi:
  ssid: !secret wifi_ssid
output:
  - platform: ledc
    pin: GPIO25
    inverted: True
light:
esp32_touch:
 # setup_mode: true
binary_sensor:
  - platform: esp32_touch
    pin: GPIO32
    threshold: 1250
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
  interface: hardware
display:
  - platform: ili9xxx
    model: st7789v
    spi_id: spihwd
    data_rate: 40MHz
    dc_pin: GPIO02
    reset_pin: GPIO04
    spi_mode: MODE3
    dimensions:
      width: 240
      height: 240
      offset_height: 0
      offset_width: 0
    invert_colors: true
time:
  - platform: sntp
    on_time_sync:
      - script.execute: time_update
    on_time:
      - minutes: '*'
        seconds: 0
        then:
image:
  - file: https://esphome.io/_static/favicon-512x512.png
    resize: 200x200
    type: RGB565
    transparency: alpha_channel
lvgl:
  buffer_size: 25%
  top_layer:
    widgets:
      - label:
          text: "\uF1EB"
          hidden: true
          align: top_right
          x: -2
          y: 7
          text_align: right
          text_color: 0xFFFFFF
      - obj:
          x: 0
          y: 0
          width: 100%
          height: 100%
          bg_color: 0xffffff
          bg_opa: COVER
          radius: 0
          pad_all: 0
          border_width: 0
          widgets:
            - image:
                align: CENTER
                src: boot_logo
                y: -40
            - spinner:
                align: CENTER
                y: 75
                height: 50
                width: 50
                spin_time: 1s
                arc_length: 60deg
                arc_width: 8
                indicator:
                  arc_color: 0x18bcf2
                  arc_width: 8
          on_press:
  pages:
    - id: clock_page
      widgets:
        - obj: # clock container
            height: SIZE_CONTENT
            width: 240
            align: CENTER
            pad_all: 0
            border_width: 0
            bg_color: 0xFFFFFF
            widgets:
              - meter: # clock face
                  height: 220
                  width: 220
                  align: CENTER
                  bg_opa: TRANSP
                  border_width: 0
                  text_color: 0x000000
                  scales:
                    - range_from: 0 # minutes scale
                      range_to: 60
                      angle_range: 360
                      rotation: 270
                      ticks:
                        width: 1
                        count: 61
                        length: 10
                        color: 0x000000
                      indicators:
                        - line:
                            width: 3
                            color: 0xa6a6a6
                            r_mod: -4
                            value: 0
                    - range_from: 1 # hours scale for labels
                      range_to: 12
                      angle_range: 330
                      rotation: 300
                      ticks:
                        width: 1
                        count: 12
                        length: 1
                        major:
                          stride: 1
                          width: 4
                          length: 10
                          color: 0xC0C0C0
                          label_gap: 12
                    - range_from: 0 # hi-res hours scale for hand
                      range_to: 720
                      angle_range: 360
                      rotation: 270
                      ticks:
                        count: 0
                      indicators:
                        - line:
                            width: 5
                            color: 0xa6a6a6
                            r_mod: -30
                            value: 0
              - label:
                  align: CENTER
                  y: -30
              - label:
                  align: CENTER
                  y: 30
script:
  - id: time_update
    then:
      - lvgl.indicator.update:
          value: !lambda |-
            return id(time_comp).now().minute;
          value: !lambda |-
            auto now = id(time_comp).now();
            return std::fmod(now.hour, 12) * 60 + now.minute;
      - lvgl.label.update:
          text: !lambda |-
            static const char * const mon_names[] = {"JAN", "FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC"};
            static char date_buf[8];
            snprintf(date_buf, sizeof(date_buf), "%s %2d", mon_names[now.month-1], now.day_of_month);
            return date_buf;
          text: !lambda |-
            static const char * const day_names[] = {"SUN", "MON", "TUE", "WED", "THU", "FRI", "SAT"};
            return day_names[id(time_comp).now().day_of_week - 1];
Thanks, this is awesome.
FYI on esphome version 2024.9.2 240x240 res. works just fine. Looks like problem lies in underlying libraries.
So I got a SmallTV-pro (ESP32), tried a few things, and most were quite hard for a beginner.
My findings so far:
  • Using lambda to render the display means that the dimensions need to have a value of 235. But there is a bright noisy stripe in the remaining are. Using a higher value makes the display crash. (Which can be annoying because it just freezes after an update. Only after a power cycle it’s going to be all noisy and therefore obviously faulty.)
This works:
display:
  - platform: ili9xxx
    model: st7789v
    spi_id: spihwd
    data_rate: 40MHz
    dc_pin: GPIO02
    reset_pin: GPIO04
    spi_mode: MODE3
    dimensions:
      width: 235
      height: 235
      offset_height: 0
      offset_width: 0
    invert_colors: true
  • LVGL can render the full resolution.
Working code:
display:
  - platform: ili9xxx
    model: st7789v
    spi_id: spihwd
    data_rate: 40MHz
    dc_pin: GPIO02
    reset_pin: GPIO04
    spi_mode: MODE3
    dimensions:
      width: 240
      height: 240
      offset_height: 0
      offset_width: 0
    invert_colors: true
  • Neither (free) ChatGPT nor (free) Copilot produce working code. ChatGPT is a better though.
  • Even ChatGPT is mostly useless when Home Assistant itself is concerned. It often relies on outdated mechanisms and won’t stop even if told so.
But I’ve managed to display the departure time of the next upcoming train for my commute. The goal is to have a full schedule for five or so connections.
I am a totally noob on esphome - has anybody of you a bin file for me, to update it via the build in webui of the geekmagic pro (esp32) variant, please? so I can add this device to my home asssitant instance via esphome
I would like to display information from the home assistant to this geekmagic pro clock
lovely, thanks for this fine example.
Tried first with the stv-ultra and texts, which was annoying due to lack of memory when changing things. When flashing again, had to go back first to the minimal firmware always.
Your lvgl approach looks much more promising
You need to install it as a new device in the ESPHome Device Builder (install the add-on in your Home Assistant). The platform is ESP32.
After it is created you choose manual download and the legacy method.
The file you receive (*.bin) can be inserted in the update section of the SmallTV configuration website.
Looks great! Glad it worked for you. I’ve added a couple more sensor screens and now use the touch button to change between pages. Seems to work very well.
Cool, could you share that button part?
I played around a bit for my needs - I added my PV + EV sensors, now trying to use some emojis which needs some fonts to be embedded first and maybe some colors.
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  baud_rate: 0
# enable web server
web_server:
  version: 3
api:
ota:
  - platform: esphome
wifi:
  ssid: !secret wifi-ssid
  password: !secret wifi-password
output:
  - platform: ledc
    pin: GPIO25
    inverted: True
light:
esp32_touch:
  # setup_mode: true
binary_sensor:
    pin: GPIO32
    threshold: 1250
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
  interface: hardware
display:
  - platform: ili9xxx
    model: st7789v
    spi_id: spihwd
    data_rate: 40MHz
    dc_pin: GPIO02
    reset_pin: GPIO04
    spi_mode: MODE3
    dimensions:
      width: 240
      height: 240
      offset_height: 0
      offset_width: 0
    invert_colors: true
lvgl:
  buffer_size: 25%
  widgets:
    # DC
    - label:
        text: "Power: 0.00 Watt"
        x: 20 # Adjust position
        y: 20
        width: 200
        text_align: CENTER
    # Forecast
    - label:
        text: "Forecast Today: 0.00 kW"
        y: 40
        width: 200
        text_align: CENTER
    # Home Battery
    - label:
        text: "Home Battery: 0%"
        x: 20
        y: 80  # Position below power display
        width: 200
        text_align: CENTER
    - bar:
        x: 20
        y: 100
        width: 200
        height: 20
        min_value: 0
        max_value: 100
        value: 0
    # Car 1 Battery (id_4_state_of_charge)
    - label:
        text: "Car 1: 0%"
        x: 10
        y: 140
        width: 100
        text_align: RIGHT
    - label:
        text: "Car 1:0km"
        x: 100
        y: 140
        width: 100
        text_align: RIGHT
    - bar:
        x: 10
        y: 160
        width: 200
        height: 15
        min_value: 0
        max_value: 100
    # Car 2 Battery (smart_batterie)
    - label:
        text: "Car 2: 0%"
        x: 10
        y: 180
        width: 100
        text_align: RIGHT
    - label:
        text: "Car 2: 0km"
        x: 100
        y: 180
        width: 100
        text_align: RIGHT
    - bar:
        x: 10
        y: 200
        width: 200
        height: 15
        min_value: 0
        max_value: 100
  # DC Power
  - platform: homeassistant # or your actual sensor platform
    unit_of_measurement: "Watt"
    entity_id: sensor.total_dc_power # Replace with your HA entity
    on_value:
          text: !lambda |-
            return ("Sun Power: " + to_string(static_cast<int>(x)) + " Watt").c_str();
  # Forecast
    entity_id: sensor.solcast_pv_forecast_prognose_verbleibende_leistung_heute # Replace with your HA entity
    on_value:
          text: !lambda |-
            return ("Solcast remaining: " + to_string(static_cast<int>(x)) + " kWh").c_str();
  # Home Battery
    entity_id: sensor.evcc_battery_soc # Replace with actual HA entity
    unit_of_measurement: "%"
    on_value:
          text: !lambda |-
            return ("Home Battery: " + to_string(static_cast<int>(x)) + "%").c_str();
      - lvgl.bar.update:
          value: !lambda |-
            return x;
  # Car 1 Battery
    entity_id: sensor.id_4_state_of_charge  # Replace with actual entity
    on_value:
          text: !lambda |-
            return ("ID4: " + to_string(static_cast<int>(x)) + "%").c_str();
      - lvgl.bar.update:
          value: !lambda |-
            return x;
  # Car 1 Range
    entity_id: sensor.id_4_range  # Replace with actual entity
    unit_of_measurement: "km"
    on_value:
          text: !lambda |-
            return (to_string(static_cast<int>(x)) + "km").c_str();
  # Car 2 Battery
    entity_id: sensor.smart_batterie  # Replace with actual entity
    on_value:
          text: !lambda |-
            return ("Smart #1: " + to_string(static_cast<int>(x)) + "%").c_str();
      - lvgl.bar.update:
          value: !lambda |-
            return x;
  # Car 2 Range
    entity_id: sensor.smart_reichweite  # Replace with actual entity
    on_value:
          text: !lambda |-
            return ( to_string(static_cast<int>(x)) + "km").c_str();
a online lvgl editor would come in handy, looking for one
Looks really good! EV’s and solar?? Jealous. We have EV’s just no solar (yet)…
The touch button control was done by tieing a binary_sensor to the esp32_touch platform and using an on_press event.
This block added to my original post will get it working.
This will rotate forward through all pages and wrap around automatically to the first one. I am likely going to add a press-and-hold to go backwards.
binary_sensor:
    pin: GPIO32
    threshold: 1250
    on_press:
      then:
        - lvgl.page.next:
            animation: FADE_IN
            time: 300ms
I think there is a difference in the ESP module. Wheni tried to get your code working for the display, it didnt show errors but just showed a screen of white noise.
Thx AoSpades - you pointed me to the right direction :slight_smile: I have flashed the device and added it to ha successfully :slight_smile:
now starts the hard stuff, right? how to customize the screen :wink: I would like to show PV information - is it possible to show mqtt device information?
Are you able to share a photo of the module side of your board? There appear to be some modified and/or clones of the original geekmagic devices that might be different enough to not work with this config.
