Installing HACS
I am trying to install HACS (so I can install the Meross integration).
I am following the instructions here:
I get the error: “! Add-on not found” when trying to add the add-on repository.
I am using HAOS 15.0 (I can’t upgrade at the moment - another error “no supervisor internet connection”) running on a PC. I am following “OS/Supervised”. I know there is an Internet connection, since I can access my HA from the Internet on my phone.
I’ve tried using Google for an answer, but couldn’t come up with anything.
HA versions:
  • Installation method Home Assistant OS
  • Core 2025.6.0
  • Supervisor 2025.05.5
  • Operating System 15.0
  • Frontend 20250531.2
Can anyone please help with this?
Start by verifying your DNS settings.
OS/Supervised is the tab in the HACS docs which tells you how to install HACS, not the OP’s install method.
Gotta admit I was about to post the same thing you did & had to read the post 3 times to click
This seems to be at the heart of your troubles
