Is it possible to access from abroad as
https://mydomain.duckdns.org:8123 (specifying the port)
and then in the router forward port 8123 to port 443 of the VM holding HASSIO?
What would I need to put in configuration to make it work?
p.s. Why I need this? Because I am trying to setup more then one server/software, and they all require port 443 to be forwarded in order to work well. On the other I am not able to fix it, so I was thinking of changing HASSIO installation (at the moment is the server/software to which I forward port 443, and I access it succesfuully from https://mydomain-hassio.duckdns.org)
