What system are you using, Debian or Raspbian ?
Are you able to ping to your gateway ?
Is your WiFi not working for internet connection (ping 8.8.8.8) or local area connection (ping to your gateway) ?
Can you show result of command āip routeā
Actually I was trying to connect via SSH previously with no success via wifi (for LAN itās working). I connected monitor and keyboard to the board now and tried to ping. Network is unreachable. Attached the output.
How connect to your WiFi ? Looks like WiFi interface completely down, since there are no routing table.
Check your wlan0 status with command
ip a
If Interface down, bring it up with.
ip link set wlan0 up
Any try to re-configure your WiFi with network-manager by.
nmtui
ip a
So here smth wrong with wlan0 as I understand. But itās already up.
nmtui
Tried it⦠There is no wireless connection option in āActivate a connectionā.
Hmm strange I never have problem with WiFi in Debian with my Raspberry pi 3.
I mainly use WiFi for my Pi too.
Mostly I have problem with Raspbian since Dhcpcd conflict with Network Manager but I able to manage this so I stick with Raspbian since Iām familiar with this.
However, HAS installation script are modify /etc/network/interfaces. you may need to check this, or try to not modify /etc/network/interfaces during HAS installation prompt.
I configured manually wifi connection via network manager. Restarted the interface and it got ip address. I didnāt try ssh though. Restarted the board and wifi is gone again. Itās super strange for meā¦
Indeed, I use Raspbian. And aptitude, which was going to remove Docker. So I marked it manually as ākeepā. But I did not pin the version, so apt(itude) upgraded the Docker version.
Everything works now, except that HomeAssistant does not start by itself anymore. hassio_observer starts upon reboot, but I have to manually start the homeassistant container (or was it hassio_supervisor?). I try to understand how Docker works, and how the different containers that depend on each other do start each other.
It did work, before upgrading Docker, so I would like to use the original startup mechanism, but I cannot find much documentation about how this convenience scripts sets-up things. On https://www.home-assistant.io/installation/raspberrypi I read about using Docker-compose. Is that also what the convenience script uses?
Your help is very much appreciated.
There is a bug in docker-ce-cli in version 20.10.4 there is a link to a post with a fix here Installing Home Assistant Supervised on a Raspberry Pi with Debian 10
Raspbian is no longer a supported OS (hasnāt been for close to a year), so keep in mind you may run into issues with the HA Supervisor, update errors, etc. This guide specifically covers the use of Debian 10 on the Pi as well as using apt
not aptitude
, so YMMV.
Updated to new docker 20.10.5, and all is fine now. After a reboot, everything works.
Next time I configure my Raspberry SD with a new OS, I will use plain Debian, and not Raspbian then.
Still, itās not completely clear to me how the framework of running Homeassistant supervised in a Docker container works, and how elements depend on each other. To be more specific: which should be started first, and then starts all the rest. Iām beginning to learn, but I could not find an overview somewhere.
- What starts the framework in the first place, and is that done via init.d or systemd or something else?
- I the Docker server started separately, and does something start the Homeassistant containers when Docker is up? Or does Docker restart the last running containers? Or is it someway else?
- Which of the Homeassistant related containers is started first? Is that hassio_observer, hassio_supervisor, or the homeassistant container? Or -again- something else?
Some of my questions may be more generic, but most of the answers may be specific for Homeassistant Supervised in a Docker container on a Rapsberry Pi (either running Debian 10 or Raspbian, that will not matter here I guess).
Q: āA container is based on an image. But when a new image of Homeassistant is installed, the settings, history, etc are maintained. How do I find where is the file (I suppose it is somewhere outside the container) to keep that recovers my complete home-assistant configuration and history and record? I guess that is a configuration option that is passed to the homeassistant container when that is started, but how do I retrieve that on a running system?ā
A: I think I resolved this last question. I installed Portainer, and inspected the homeassistant container. And it shows that /data in the Docker container is mounted on (>Mounts>0>Source) /usr/share/hassio, where I can find a file homeassistant/home-assistant_v2.db. This must be the database, and the current configuration is indeed in configuration.yaml.
I cannot find, though, where the configuration is that tells that this is the location that is mounted in the Container, or is that a fixed location set in the image of homeassistant?
Did a fresh install and also had the issue with docker, downgraded as recommended and it started working fine afterwards, sans the power/SD access leds. Is that expected behavior on Debian? Any way to enable them anyway if so?
I do find it very odd Iām getting about 1.7GB of ram usage now while the exact same HA install plus octoprint and a few other things on top of the 64 bit RaspbianOS install I migrated from never broke the 1.2GB mark. Not sure on how Iād go about tracking down the reason, if anyoneās got any pointers they can share thatād be very much appreciated.
I gather everytime we do an OS upgrade now weāll need to redo the docker downgrade? Well, until it is fixed at the source.
Didnāt work for me
[email protected]:~ $ sudo apt install docker-ce-cli=5:20.10.3~3-0~debian-buster
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Version '5:20.10.3~3-0~debian-buster' for 'docker-ce-cli' was not found
EDIT: This worked
apt install docker-ce=5:19.03.15~3-0~raspbian-buster docker-ce-cli=5:19.03.15~3-0~raspbian-buster
It was fixed at the source a few days ago. 20.10.5 is fine.
LOL, I just downgraded to 19,03.15. I guess Iāll update again.
Still doesnāt work for me (after a reboot)
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
a1b5ea850f5a homeassistant/armv7-addon-configurator:5.2.0 "/init" 5 days ago Exited (0) 33 minutes ago addon_core_configurator
258398e869bc hassioaddons/portainer-armv7:1.3.0 "/init" 5 days ago Exited (0) 33 minutes ago addon_a0d7b954_portainer
8cf7e3ee0158 homeassistant/armv7-addon-ssh:8.10.0 "/init" 5 days ago Exited (0) 33 minutes ago addon_core_ssh
2085d4ae6823 homeassistant/armv7-addon-duckdns:1.12.4 "/init /run.sh" 5 days ago Exited (129) 33 minutes ago addon_core_duckdns
ab9bcda7e794 hassioaddons/sonweb-armv7:0.13.1 "/init" 5 days ago Exited (0) 33 minutes ago addon_a0d7b954_sonweb
353c19dae841 homeassistant/armv7-addon-mosquitto:5.1 "/run.sh" 5 days ago Exited (137) 32 minutes ago addon_core_mosquitto
a5f5a0376107 homeassistant/armv7-hassio-multicast:3 "/init" 5 days ago Exited (0) 33 minutes ago hassio_multicast
92b8ccc1a6f3 homeassistant/armv7-hassio-cli:2021.02.1 "/init /bin/bash -c ā¦" 5 days ago Exited (0) 33 minutes ago hassio_cli
29cf57f016fc homeassistant/armv7-hassio-audio:2021.02.1 "/init" 5 days ago Exited (0) 33 minutes ago hassio_audio
f3f71e85d90b homeassistant/armv7-hassio-dns:2021.01.0 "/init" 5 days ago Exited (0) 33 minutes ago hassio_dns
8ceaa36b7e59 homeassistant/armv7-hassio-observer:2020.10.1 "/init" 5 days ago Up 2 minutes 0.0.0.0:4357->80/tcp hassio_observer
aa8eeb518073 be11a28f19e8 "/init" 13 days ago Exited (0) 34 minutes ago hassio_supervisor
2c9a3397b98c homeassistant/raspberrypi3-homeassistant:2021.2.0 "/init" 4 weeks ago Exited (0) 32 minutes ago homeassistant
EDIT: Actually, itās even worst, now supervisor doesnāt stay loaded and doesnāt spawn the other docks Loading HomeAssistant manually, I never get the port opened.
EDIT 2: Went back to 19.03.15 and behaves the same
Iāve run into the supervisor/docker issue and have not been able to resolve it with the notes Iāve found here. I am attempting to install Debian instead of Raspian I had been using in a Pi4 to be compliant with supported systems. I am stuck at getting apt to work. āThe value ābusterā is invalid for for APTā when trying to run any apt command while logged in as root. Iām sure Iām missing something obvious but I am sure after an hour and break and another hour that I am stuck. Help appreciated.
