i tried to install homeassistant on my synology ds215 with dsm 6.0.
i used installing homeassistant from the dsm paket center. while installing homeassistant, phyton3 (vers. 3.4.1-1) and git (version 2.7.4.-8) are installed too. python3 (vers. 3.5.1-0104) and python modules are instelled from the paket center earlier.
before logging in on the web gui homeassistant shows issues like “hass.local.api ist deprecated. use hass.config.api” and “componets.recorder: found unfinished sessions”. how to fix that?
logging in on web gui is impossible after setting the password in the configuration.yaml found in “@appstore/homeassistant/var/”.
i tried also to install homeassistant using command line. there’s no way to install, the permission and owner of the folders can’t be set. with “dir” i can see the folder, setting the permission failured, command line prompted, there is no folder like that.
