Installing mycroft on raspberry with home assistant in virtualnv
Hi!
I installed home assistant on a raspberry pi 3 in a virtualnv and am now thinking about installing mycroft on the same raspberry (did it before without home assistant).
Would you just follow the steps described under https://github.com/MycroftAI/mycroft-core or is there something to be aware of when installing mycroft on the same machine as the one where home assistant is running on (in a virtualnv)?
Thanks!
