Hey make need help with something on my home assistant I tried to do an integration and it
asked me for host is that a cold?
Whisper and Piper both have add-ons that need to be set up before the integration will work.
HA Docs - Voice Control - Getting started: Local - Installing a local Assist pipeline
It should be auto-discovered after you install, configure, and start the addon(s).
I deleted it and reinstalled it and still keep on asking I see a lot of Youtubers it does not ask him for that host
That’s because you’re adding the integration manually - go to your notifications and see if it was auto-discovered. make sure the add-on is running.
