Installing things via putty
I wanted to get rf outlets working on homeassistant by following this guide : https://www.youtube.com/watch?v=5UUazFbK-Hg&t=390s
But now it turns out I can’t run the commands in putty like it used to be done. I get this message:
This happens with every command i try to run.
It’s probably very basic but it would be awesome if someone could help me with this.
Thanks in advance!
I asked Ben from BRUH Automation about this on his YouTube channel. This was his response;
"Yeah, with HassIO the goal is to move totally away from the command line. Your best bet is to either create a custom AddOn or to wait for one to be made "
Basically, you can’t use those commands anymore in HassIO. There may be another way of doing what you are trying to do through HassIO if somebody has created a third party addon. Hopefully somebody will be able to answer that for you.
Hass.io is not based on Debian. Its Alpine Linux instead. The packagemanager there is called apk. Check this for more info on that: https://wiki.alpinelinux.org/wiki/Alpine_Linux_package_management
