Installing TileBoard on hassio
Hey,
I am new on HA and I want to build to UI with TileBoard, unfortunately I can’t understand how to install it on hassio.
could you help me please?
Thanks :slight_smile:
Clone the repository inside your config/www folder
Thank you :slight_smile:
Now i get 404 error when I enter to “http://10.0.0.7:8123/local/tileboard/index.html
Just to make sure, you created a new folder called “www” in your config folder, and saved the tileboard folder in there? Something like config/www/tileboard.
Is 10.0.0.7 the IP of your Pi running Hassio? Doesn’t hurt to restart home assistant either once you’ve created the folders.
i did everything and my hassio ip is 10.0.0.7
This is an example configuration file.
COPY OR RENAME THIS FILE TO config.js.
Make sure you use real IDs from your HA entities.
var CONFIG = {
customTheme: null, // CUSTOM_THEMES.TRANSPARENT, CUSTOM_THEMES.MATERIAL, CUSTOM_THEMES.MOBILE, CUSTOM_THEMES.COMPACT, CUSTOM_THEMES.HOMEKIT, CUSTOM_THEMES.WINPHONE, CUSTOM_THEMES.WIN95
transition: TRANSITIONS.ANIMATED_GPU, //ANIMATED or SIMPLE (better perfomance)
entitySize: ENTITY_SIZES.NORMAL, //SMALL, BIG are available
tileSize: 150,
tileMargin: 6,
serverUrl: “http://10.0.0.7:8123”,
wsUrl: “ws://10.0.0.7:8123/api/websocket”,
password: “******”,
authToken: null, // optional: make an long live token and put it here
//googleApiKey: “XXXXXXXXXX”, // Required if you are using Google Maps for device tracker
debug: false, // Prints entities and state change info to the console.
// next fields are optional
events: [],
timeFormat: 24,
menuPosition: MENU_POSITIONS.LEFT, // or BOTTOM
hideScrollbar: false, // horizontal scrollbar
groupsAlign: GROUP_ALIGNS.HORIZONTALLY, // or VERTICALLY
header: { // https://github.com/resoai/TileBoard/wiki/Header-configuration
styles: {
padding: ‘30px 130px 0’,
fontSize: ‘28px’
right: [],
left: [
type: HEADER_ITEMS.DATETIME,
dateFormat: ‘EEEE, LLLL dd’, //https://docs.angularjs.org/api/ng/filter/date
/screensaver: {// optional. https://github.com/resoai/TileBoard/wiki/Screensaver-configuration
timeout: 300, // after 5 mins of inactive
slidesTimeout: 10, // 10s for one slide
styles: { fontSize: ‘40px’ },
leftBottom: [{ type: SCREENSAVER_ITEMS.DATETIME }], // put datetime to the left-bottom of screensaver
slides: [
{ bg: ‘images/bg1.jpeg’ },
bg: ‘images/bg2.png’,
rightTop: [ // put text to the 2nd slide
type: SCREENSAVER_ITEMS.CUSTOM_HTML,
html: ‘Welcome to the TileBoard’,
{ bg: ‘images/bg3.jpg’ }
pages: [
title: ‘Main page’,
bg: ‘images/bg1.jpeg’,
icon: ‘mdi-home-outline’, // home icon
groups: [
title: ‘First group’,
width: 2,
height: 3,
items: [
position: [0, 0],
width: 2,
type: TYPES.TEXT_LIST,
id: {}, // using empty object for an unknown id
state: false, // disable state element
list: [
title: ‘Sun.sun state’,
icon: ‘mdi-weather-sunny’,
value: ‘&sun.sun.state’
title: ‘Custom’,
icon: ‘mdi-clock-outline’,
value: ‘value’
position: [0, 1], // [x, y]
width: 1,
type: TYPES.SENSOR,
state: ‘@attributes.release_notes’ // https://github.com/resoai/TileBoard/wiki/Templates
           title: 'Second group',
           width: 2,
           height: 3,
           items: [
                 position: [0, 0],
                 width: 1,
                 type: TYPES.SLIDER,
                 //id: "input_number.volume",
                 id: {state: 50}, // replace it with real string id
                 state: false,
                 title: 'Custom slider',
                 subtitle: 'Example of subtitle',
                 slider: {
                    min: 0,
                    max: 100,
                    step: 2,
                    request: {
                       type: "call_service",
                       domain: "input_number",
                       service: "set_value",
                       field: "value"
                 position: [1, 0],
                 width: 1,
                 type: TYPES.SWITCH,
                 //id: "switch.lights",
                 id: {state: 'off'}, // replace it with real string id (e.g. "switch.lights")
                 state: false,
                 title: 'Custom switch',
                 icons: {'off': 'mdi-volume-off', 'on': 'mdi-volume-high'}
                 position: [0, 1],
                 type: TYPES.ALARM,
                 //id: "alarm_control_panel.home_alarm",
                 id: { state: 'disarmed' }, // replace it with real string id
                 title: 'Home Alarm',
                 icons: {
                    disarmed: 'mdi-bell-off',
                    pending: 'mdi-bell',
                    armed_home: 'mdi-bell-plus',
                    armed_away: 'mdi-bell',
                    triggered: 'mdi-bell-ring'
                 states: {
                    disarmed: 'Disarmed',
                    pending: 'Pending',
                    armed_home: 'Armed home',
                    armed_away: 'Armed away',
                    triggered: 'Triggered'
           title: '',
           width: 1,
           height: 3,
           items: [
                 // please read README.md for more information
                 // this is just an example
                 position: [0, 0],
                 height: 2, // 1 for compact
                 //classes: ['-compact'],
                 type: TYPES.WEATHER,
                 state: function () {return 'Sunny'}, // https://github.com/resoai/TileBoard/wiki/Anonymous-functions
                 icon: 'clear-day',
                 icons: { 'clear-day': 'clear'},
                 fields: {
                    summary: 'Sunny',
                    temperature: '18',
                    temperatureUnit: 'C',
                    windSpeed: '5',
                    windSpeedUnit: 'kmh',
                    humidity: '50',
                    humidityUnit: '%',
                    list: [
                       'Feels like 16 C'
                       'Feels like '
                          + '&sensor.dark_sky_apparent_temperature.state'
                          + '&sensor.dark_sky_apparent_temperature.attributes.unit_of_measurement',
                       'Pressure '
                          + '&sensor.dark_sky_pressure.state'
                          + '&sensor.dark_sky_pressure.attributes.unit_of_measurement',
                       '&sensor.dark_sky_precip_probability.state'
                          + '&sensor.dark_sky_precip_probability.attributes.unit_of_measurement'
                          + ' chance of rain'
     title: 'Second page',
     bg: 'images/bg2.png',
     icon: 'mdi-numeric-2-box-outline',
     groups: [
           title: '',
           width: 2,
           height: 3,
           items: [
                 position: [0, 0],
                 width: 2,
                 title: 'Short instruction',
                 list: [
                       title: 'Read',
                       icon: 'mdi-numeric-1-box-outline',
                       value: 'README.md'
                       title: 'Ask on forum',
                       value: 'home-assistant.io'
                       title: 'Open an issue',
                       icon: 'mdi-numeric-3-box-outline',
                       value: 'github.com'
solved :slight_smile:
uppercase problem …
Hey,
saw the tutorial yesterday and wanted to implement this to my HomeAssistant installation on my RaspberryPi.
Sorry if i am too stupid but where exactly do i find the “www” folder to paste the config files???
