I am new to the forum and new to Home Assistant.
I have purchased the Aeotec Z-Stick Gen 5. I am running Hass.io version 1.13 on a Raspberry pi 3 Model B but I cannot get it to work.
the hassio hw info command gives the following snippet …
“result”: “ok”,
“data”: {
“serial”: [
“/dev/ttyAMA0”,
“/dev/ttyACM0”
I have added the following to the configuration.yaml file (Note that I have tried both ACM0 and AMA0)
Z-Waves
zwave:
usb_path: /dev/ttyACM0
The OZW log file says …
2018-12-01 19:45:44.852 Always, OpenZwave Version 1.4.3254 Starting Up
2018-12-01 19:45:45.941 Info, Setting Up Provided Network Key for Secure Communications
2018-12-01 19:45:45.943 Info, mgr, Added driver for controller /dev/ttyAMA0
2018-12-01 19:45:45.944 Info, Opening controller /dev/ttyAMA0
2018-12-01 19:45:45.944 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2018-12-01 19:45:45.944 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2018-12-01 19:45:45.944 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-12-01 19:45:45.945 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2018-12-01 19:45:45.945 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2018-12-01 19:45:45.945 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2018-12-01 19:45:45.945 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2018-12-01 19:45:45.945 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-12-01 19:45:45.945 Detail, contrlr, Notification: DriverFailed
An ls command of /dev gives the following
core-ssh:/dev# ls
fd init null pts shm stdin tty zero
full mqueue ptmx random stderr stdout urandom
There is no /dev/ttyACM0 or /dev/ttyAMA0.
Is that the issue causing the DriverFailed?
Any help appreciated. I am new at this.
Thanks.
