Using the Windows portable version of home assistant, I was able to get the insteon integration mostly working, but I’ve found that the on/off switches are not quite working. For example: If I turn ON the top outlet, it turns on and shows its status correctly. However, after a slight delay, the bottom outlet also shows that it is ON even though it did not turn on. Is there a configuration, setting, or command to fix this issue?
I have a similar issue, where the status of bottom outlet changes to ON, while it is actually off. Also you cannot switch the status to OF, i just returns to ON.
I have also seen a similar incorrect status with ON/OFF light switch, but interestingly not all of the ON/OFF switched that I have, only a few, but always the same few.
