Insteon integration YAY!
I just started rebuilding my HA Raspberry Pi system tonight after a couple of frustrating weeks trying to figure out how to get Insteon set up on it. I have a lot of Insteon/X10 devices.
This latest version actually has the Insteon integration available on startup!!!
I just want to say thanks to whosoever is responsible for that!!
You are welcome. :slight_smile:
Feel free to ask questions as they come up.
Any input on how to resurrect my X10 devices after after a reboot would be greatly appreciated.
Was surprised this week when I had to restart after some setting changes.
Ron, If you are using HA version 0.115 or higher you can go to Configuration -> Integrations and you should see Insteon there as a card. Click on the Options button and it will walk you through setting up X10 devices. I would also recommend removing any insteon configuration from your configuration.yaml file.
Thanks, Tom. I had no issues setting them up initially.
What I meant was that after a reboot my X10 devices went orphaned and needed set up again.
Is there a simple fix for that after rebooting?
And btw- what is the easiest way to decommission X10 addresses as I replace with Insteon devices.
Can the yaml just be edited and the devices removed?
X10 devices should survive a restart so I am not sure why you would need to add them again after a reboot.
