Insteon server down?
Insteon server down need solutions to control my home via Alexa and remotely from mobile device’s
Get an Insteon PLM if you don’t already have one, and hook it directly to your Home Assistant with Insteon-MQTT.
You can use your hub with the built-in Insteon integration. I believe the MQTT integration supports the hub now as well If you sign up for the HA Cloud solution ($5 per month) it comes with Alexa and remote control of all your devices in Home Assistant
