Insteon setup stopped working
Hi! I’ve been using HA successfully for a large number of Insteon switches and dimmers for quite some time now. However, after a recent upgrade to to 0.108.0 (and then back to 0.107.6, and then back to 0.108.1), it has stopped working.
My config for the 2413U is very simple:
insteon:
  port: /dev/insteonusb
However, none of my devices are controllable anymore. Here’s an example of trying to turn on a dimmer, which does nothing:
2020-04-09 09:15:33 DEBUG (MainThread) [insteonplm.devices] Starting 40.AD.17 Device._send_msg: Queuing message
2020-04-09 09:15:33 DEBUG (MainThread) [insteonplm.devices] Starting 40.AD.17 Device._process_send_queue
I’m unfortunately at a loss, as this has worked fine for months and months. (Years?). One thing I notice: my Insteon devices only show up under “Entities”, but not “Devices”. I don’t know if has always been like that? Or of it’s a clue.
Here’s a grep of “insteon” from my logs, after a complete reboot and restart of the HA docker. Patebin: https://pastebin.com/P9td3f5u
If you got this far, thanks!
I created a github issue to track this: https://github.com/home-assistant/core/issues/33917
Okay, so it turns out this was the same “multiple instances of HA running in the docker”, as noticed in issue #32992
I run docker via Portainer, and had to clear out the command, and now things work.
