Can you please add support for the 2744SA Load Controller. Thank You
I have developed the code to support this device and am hoping to have it supported in HA in the 2022.6 release. Stay tuned.
That would be great, I installed the lastest HA this week and although I can add the Insteon Load Controller its not visible on the Insteon dashboard. I have mine running a pool pump that runs the heater … ill certainly look forward to 2022.6 Thanks again for all your work! Much appreciated
Due to some timing issues I am not expecting to complete this until 2022.7 now. Sorry.
Well noted, will be patiently awaiting the update when possible. Thanks again.
Adding my thanks for your efforts, I have 2 2744 controlling water heaters at my cottage. My experience is the same as MattQC, I can successfully link the device to the hub (HA acknowlwdges adding the device), but it does not show in my device list. Thank you again,
Installed 2022.8.5 today and got a great surprise. My 2744SA appeared as a new device. Got it into my automation and working great
Thank you teharris1 for your support for all us Insteon migrants and helping take it to a new level
I am running the windows version of HA. I see from my UI that I am running 2022.8.6. I cannot get my 2744SA to appear. I’ve tried putting it in linking mode, toggling the switch on the 2744SA itself hoping the HA will see it, doing a call service for add all links… no luck.
Any tips on this one? Is there a way to force HA to see the device? Initiate a refresh of all devices?
I am by no means an expert. Here’s what I would do.
First try linking again
In HA, go to Insteon Configuration page
Click on the + Add Device button
On the Add Insteon Device screen, Click OK
On the “Adding Insteon device - ready to pair…” screen, goto the 2477SA and press the set button
until it beeps, you should get a HA dialogue indicating the device is added, this can take a few seconds. In my situation, I had to try the Add Device routine a couple of times
So, assuming you have tried this several times, I would next hard reset the 2477SA and then try the add.
240V Load Controller Setup — Insteon
Resetting 240V Load Controller to its Factory Default Settings
The factory reset procedure will clear 240V Load Controller of all INSTEON links and programmed X10 addresses.
NOTE: Depending on the location of your circuit breaker or fuse panel, you might need to recruit
someone to help you perform the following procedure.
- If you are using a controller to control 240V Load Controller, be sure to unlink it from the controller.
See Unlinking 240V Load Controller from an INSTEON Controller. - If you are using 240V Load Controller to control any INSTEON devices, unlink those devices from
240V Load Controller. See Unlinking an INSTEON Responder from 240V Load Controller. - At the circuit breaker or fuse panel, disable the circuit supplying power to the junction box for about
10 seconds - While holding down the Set button on 240V Load Controller, re-enable power to the junction box from
the circuit breaker or fuse panel, making sure not to let go of the Set button
240V Load Controller will beep - Continue to hold down the Set button for 3 seconds and then release
A few seconds after you release the button, 240V Load Controller will double-beep and its Status
LED will turn on solid green
The load will turn on
Lastly, I have seen a couple comments, about Insteon trouble with 2022.8.6. I do not know if that is real or not. I am running 2022.8.5 and it is working fine. So as a last ditch effort, go back to 2022.8.5 with a saved 2022.8.4 or 5 full backup and try again.
I am sure there are some more tech oriented folks that may have other debugging ideas.
Good luck
