I am tracking the heat provided by the heat pump.
Heat is calculated with returning / leaving water temperatures and flows.
Sometimes, when the heat pump is not running for some time the heat integral sensor is having jumps. Although I set the max sub interval to 30sec.
The setup is the following:
Here a jump (upper graph is the intergral sensor, below the signal of the heat):
Any guess, on why there is such a big jump all of a sudden?
