I bought a 433 Mz receiver with which I would like to control a ‘Digoo’ temperature sensor but not only that, I am using HassOS (no Home Assistant) on a raspberry pi4, I connected it to the raspberry as shown in the image, I tried to make him recognize HassOS but to no avail,
there is someone who can give me directions
thank you
Hello.
Could you share your Digoo sensor model? Pilight can be a solution with this type of receiver.
You can check if your sensor is in the list of supported devices.
If not, an alternative is to use rtl_433 with an rtl_sdr (you would need to check supported models also).
this is my DG-R8H sensor
sorry but i saw the message just now
