Integrate Music Assitant in docker on a different host than HA
Been running HA for a while now … so my installation is still using a virtual environment (on an lxc container ). Looking to try out Music Assistant and obviously the addon install method doesn’t work… so looking to use docker. Question: Can I run the docker instance on a different host than HA is running? The new docker container network would be on the same subnet as my HA instance.
Thanks in advance!
j
