Integrate rain gauge
I know there are many topics on this, but in my opinion no topic fits my task.
I have build a weather station with a rain gauge:
The gauge transmits the following data using a webhook:
Sample Time (Timespan between the samples)
Rain value for an hour. (Means: wenn the weather station gets power first time, it resets this value every hour)
Rain value / hour (Means: (Rain value / sample time)*timeForAnHour)
I can now display two values in my home assistant UI:
Rain as liter/h
Rain last hour
What i want to have and configure is a simple 24 h (or 48h) graph which displays the rain value for every hour. Where should i start? Is this possible to archive in the UI. E.g. using a template helper and display the helper in some kind of UI element?
I also found the “Utility Meter” but i am not sure if i configured it correct. What UI element should i choos to display the utility meter data?
Oh, and i also found this history stats sensor.
Is it possible to create this sensor in the home assistant UI, or do i need to do this completely in yaml code?
I hope someone can help me. :slight_smile:
So, i started now to create a history_stats sensor but i am not sure if this is what i need.
There is a configuration variable “state” which should be the state which i want to track, but what should i put in there.
I also send the delta rain gauge impulses for each transmit periode to the webhook.
the example says
entity_id: light.my_lamp
state: “on”
but i can not set state to “on”. This makes no sense.
My entity to track is a input number
input_number.weatherstation_rain_gauge_delta_bucket_count_from_webhook
There is no need to create a new sensor, you already have what you need.
Use this card:
To display this sensor:
Bonus: If you want a daily total sensor you can use a utility meter helper with a daily cycle that uses your “Rain last hour” sensor:
Thank you! :slight_smile: I will have a look at your suggestions.
