Integrate smart home provider “Meroos”
Is it possible to integrate the smart home provider “Meroos” into Home Assistant. I have garage door openers, water sensors and switch sockets, all of which cannot be used in Home Assistant.
Really “Meroos” or did you mean to write “Meross”?
For the latter, check out GitHub - krahabb/meross_lan: Home Assistant integration for Meross devices
Sorry Meross is right. I use Home Assistent in Docker Container on Synology. In Container it is not possible to use Add ons.
The link is to an integration.
Not an addon.
I can’t find “Meross” in the list of integrations - did you manage to connect your Meross devices?
I have 4 smart plugs, it worked back in 2021 (or 2022) & a new install in docker (2024.5.5) doesn’t show any integrations:
The Meross integration seems to be a third party one, so it needs to be installed manually or through HACS.
oh thanks for pointing that out - I didn’t realize there was a separate repository!
I’ll follow the instructions I found here:
That sounds right then.
You then need to find your wanted integration in HACS and install it.
This installs the third party integration in the HA integration store.
Once the integration is in the HA store then you can go to the HA integration page and add the integration from there.
And first then will the integration be available to use.
