I’ve integrated the DWD weather service into Home Assistant. Would it make sense to uninstall the previous met.no integration to optimize system resources (memory/CPU usage)?
If you are not using an integration there is no point in having it installed. Doubt you will see anything on the resource usage though.
I’d run them side-by-side for 2-3 months so you’re able to have a closer look on some exciting weathercoditions and check which provider matches most.
I used 4 differnt ones for half a year and then kept openweathermap but this surely depends upon your location.
