Hello, i hope this isnt the wrong website to ask for things like that and hopefully the right thread. If not please delete it.
I’m doing a heating retrofit and just had a Mitsubishi Heavy Industries KX-series VRF system quoted: 1x outdoor unit FDC140KXZES1, 7x indoor console units FDFW(22)28KXE6F, each paired with an RC-ES1 wired touch remote. Install is scheduled for the end of September.
My installer quoted smart-home integration as extremely expensive per indoor unit, so it’s not happening unless I DIY it myself. I’d really like to keep the RC-ES1 remotes (not swap them for RC-EX3, which I know has a working community hack).
To save people time, here’s what I’ve already dug into and ruled out for my exact hardware:
MHI-AC-Ctrl (GitHub - absalom-muc/MHI-AC-Ctrl: Reads and writes data (e.g. power, mode, fan status etc.) from/to a Mitsubishi Heavy Industries (MHI) air conditioner (AC) via SPI controlled by MQTT · GitHub) — taps the internal SPI bus inside the indoor unit via ESP8266. Confirmed only for SRK/SRC/SRF/DXK residential single-splits, not FD/KX console units.
hump-coder/mhi-rc-ex3-esp32 / mhi-rc-ex3-esphome — solid ESPHome climate integration by tapping test points on the remote’s PCB, but explicitly built for the RC-EX3/RC-EXZ3A remote, not RC-ES1.
albertvaka/MHI-WifiController — a man-in-the-middle device on the 3-wire bus between remote and indoor unit (no need to open anything). Confirmed only for the older RC-E1 remote and 2004–2006 indoor units.
ProtoART CNS-Interface / XY-Interface — their published supported-models lists don’t include the KX/KXE6 series or RC-ES1 (CNS covers SRR/SRF/DXK, XY covers FDTCVH/FDUMVH). I’ve emailed them directly to ask.
Intesis/HMS Networks gateways (MH-RC-WMP-1, MH-RC-KNX-1i, 700-series Superlink II gateways) — these are the “official” professional path, but their documented compatible remotes for the KXE6 series are RC-E3/E4/E5/EX1A/EX3/EX3A/RCH-E3 — RC-ES1 doesn’t appear anywhere in their docs either.
So: has anyone actually gotten a KX-series VRF system with RC-ES1 remotes talking to Home Assistant official gateway, reverse-engineered bus tap, anything? Ideally without having to open the indoor units themselves. Happy to share findings back if I get anywhere with ProtoART or Intesis support.
