Thank you for taking the time to document this process. I have been having non-stop issues with Stunnel and have been trying to figure out how to use the NGINX Proxy Manger instead, but was never able to get it to work. Your step-by-step processed worked great and I am now able to connect to my BI server remotely without any issues. Thanks again for sharing.
The next thing I would like to get working is to use Tensorflow AI Addon to help filter out false motion triggers. I have read this can work, but have not found any detailed documentation on how to set this up to work with the BlueIris feed. I am currently paying $5/month for the sentry smart alerts AI, but would prefer to setup my own internal solution. If anyone has additional information on how to get the TensorFlow Addon working with BI I would appreciate the info or link.
Sorry for the message after almost 6 months.
I just installed blueiris on a nuc in Windows 10. The only thing on it.
My hassio setup is on an unRAID VM Server (on a separate machine then the nuc). Also using NABU CASA.
How might I use your functionality in my environment.
I have followed this tutorial carefully, in hopes of correcting an existing issue, but, alas, I am still having the problem. When opening the android app for example ā¦ if it is left open, and I come back to it, my home assistant instance will briefly loose connection, and when the connection comes back, my previews of my cameras show up as grey boxes with a missing link logo. I usually just refresh the screen, and it fixes the problem, however, the new Android app doesnāt have a refresh option. I have lived with this for quite some time, but I am becoming more and more annoyed and I am not certain what the problem is. Anyone else with a similar issue?
I am not able to get Home Assistant (Lovelace front-end) to load my Blue Iris streams.
- platform: generic
name: Front Door Stream
username: !secret blueiris_username
password: !secret blueiris_password
authentication: basic
still_image_url: "http://***.***.*.***:**/image/front_door"
stream_source: "http://***.***.*.***:**/h264/front_door/temp.m3u8"
The stream opens locally on the Blue Iris host machine, and Home Assistant appears to be refreshing the still images, but, clicking the image in my front-end just results in a spinning wheel, and never loads the stream. I have double, and triple checked the links, and the username & password, and all is correct. The system is set up using this tutorial. I am on Hass.io, v. 0.105.5, and show no errors in the log related to this. For what itās worth, the mjpeg set-up as indicated in the original post works fine, just not the stream version. I am wondering if the correct link should be something like: http://my.domain.duckdns/h264/front_door/temp.m3u8. Any advice?
I just use a chrome shortcut on my phoneā¦ that way it works just like the app but has refresh and the rest of chromeās features.
Also, I have to give it to the opā¦ awesome write up on securing remote BI access. I would probably be trying this, but before I put cams on my house I already had a VPN setup on my asus router. That provides plenty of security and speed since Iām using self signed certs (4k aes) with the newer gcm ciphers.
At the end of the day I think a vpn is the way to go for my needs. It shotguns all of my remote access needs with one bulletā¦ not just ha and bi, I can also rdp or samba to windows machines, nas, etcā¦ anything in my lan.
I am having the same issue where I cannot use the Generic Camera integration for Blue Iris. I think I have narrowed it down to an BI authentication issue. If I set Blue Iris Authentication to anonymous or Non-LAN Only to test, it works just fine. I checked the Blue Iris messages when I set the Blue Iris Authentication to be required on āAll Connectionsā and I receive <my_HA_ip>:AuthFailed. The MJPEG camera setup works with my same secret username and password, so I know it is not that. Anyone solve for authentication problems with Generic Camera and BI?
I should add the reason to use the Generic Camera is the new functionality to see your cameras on the Alexa Echo Show. You need to use the stream integration for this to work and as far as I am aware it doesnāt work with MJPEG Cameras.
I should also add, in order to see the AuthFailed message in BI, I had to turn on āLog ALL connections, not just loginsā in Web Server > Advanced settings.
Turning on BI Web Server > Advanced āUse Secure Session Keys and Login Pageā allows Home Assistant to connect, but keeps repeating a login in BI connections but camera doesnāt stream in HA. It appears Basic Auth is not working with Generic Camera for BI like it does with MJPEG Camera.
is it possible to cast the cameras with this setup? currently I use mqtt but can only cast if authentication is set to non-lan and the anonymous account has to be enables. With the anonymous account enabled the ui3 interface logs in without credentials. So trying to secure my setup but still have ability to cast.
Iāve got this mostly working but with 9 cameras, soon to be 10, it appears some of my cameras donāt show the stream in HA. If I limit the picture entities, these cameras can work, so itās not an issue of any specific camera, but something to do with bandwidth maybe? Max simultaneous connections?
Were you ever able to get the BI stream working with the Echo Show? Iām able to add the generic camera to Alexa, and I can ask to see it, but after loading āā¦ Home Assistantā, for a few seconds, it simply quits. Not sure what can be done at this point.
Anyone having issues with low FPS when using Blueiris mjpeg streams?
Iām only seeing 1-2fps when pulling an mjpeg feed from the server. The server hardware or network is not the issue. Fluid 30fps everywhere else with h264.
2nd day of trying this after exhausting all other free programs (motioneye, ispy, etc). This is miles ahead. After a few hours of tweaking and testing I am impressed. Mqtt working and http commands from ha to switch profiles. Nodered picks up mqtt and does what I need. Always had false alerts with light changes - this is looking promising.
Just found the entire blue iris nvr hacs integration! awesome!
But on the fork AI tool I still get the objects identified outside the mask. I used the mask tool on the AI tool. I assume the coloured in area it is supposed to ignore.
Also no rectangles around the identified objects anymore. Why?
I donāt know what the AI tool is, but on the standard motion sensor hot spots, the colored area is the area you want monitored. Not a mask that you donāt want monitored.
