Integrating Connect ZBT-2
I want to integrate my HA Connect ZBT-2 as a Zigbee device (maybe Thread later) into my HA installation. When I plug it into my HA host I should automatically get a configuration window, but I don’t. I can’t find the integration from inside my Home Assistant, but I can find it on “Home Assistant”. There (if I use the Vivaldi browser, not Firefox) I am presented with the option of integrating it into my HA, but that doesn’t work (“not_implemented”). Any suggestions on what to do? Indeed, my ZBT-2 has a history - it has been flashed using “zbt2_zigbee_ncp_7.4.4.5.gbl”.
Regards Jonas
Look in Settings/System/Hardware:
  • Under Configure All Hardware, make sure it has an entry for the connection to the HA server
  • You should see “Home Assistant Connect ZBT-2” at the same level where you configure it
The thing to note is that it’s an either/or, the setting allows me to pick either Thread or Zigbee, not both
