Integrating Emonpi energy usage with home assistant, no return to grid/export reading
Hi
I am try to integrate Emonpi with home assistant so i can turn plugs on etc to use excess solar instead of exporting. I have got import and solar readings but cant find or work out how to get return to grid reading? Any help would be appreciated Thank you.
Do you have export and export_kwh feeds configured in emoncms?
Mike
Hi Mike
yes, but it is logged as + & - on ct1 sensor. Just started using home assistant and it is a bit of a learning curve.
Thank’s
Mark
Could you show me your configuration of the export feed in emoncms
any help would be appreciated, as i am struggling a bit.
Hi @Hailstoneuk
I think what you have tried is to set a feed via postprocess, right?
There is here a post that accomplish this in the emoncms forum:
I hope it helps!
