Integrating INNR Bridge
I have an Innr system running zigbee lamps and also run home assistant. I know i can link my zigbee devices but can you link the bridge? I need to do this so i can use the remote switches.
Any help would be appreciated
Innr Bridge with Home Assistant? - Hardware - Home Assistant Community
Assuming the remote switches are zigbee too, then you can add them as well to a HA-integrated zigbee solution, e.g. Zigbee2MQTT
Zigbee2MQTT Innr compatible devices
