Integrating Xiaomi Mi Scale
Happens to the best of us :smiley:
Don’t forget the template editor, it will give you lots of helpful hints
Thank you a lot :pray:
I never used template editor before for don’t know about it😀.
As per your suggestion, I knew it already and gave it a try
HA changed recently the definition of the manually configured MQTT sensors
Please advise how should I change my actual configuration:
  • platform: mqtt
    state_topic: “miscale/weight/kg”
    unit_of_measurement: “kg”
  • platform: mqtt
    name: “MiScale Impedance”
    state_topic: “miscale/impedance”
    unit_of_measurement: “Ω”
  • platform: mqtt
    name: “MiScale Datetime”
    state_topic: “miscale/midatetime”
    unit_of_measurement: “Datetime”
  • platform: mqtt
    state_topic: “miscale/cinematics/weight”
    value_template: “{{ value_json[‘weight’] }}”
    json_attributes_topic: “miscale/cinematics/weight”
    icon: mdi:scale-bathroom
  • platform: mqtt
    value_template: “{{ value_json[‘bmi’] }}”
    icon: mdi:human-pregnant
    unit_of_measurement: “kg/m2”
I’ve managed with this configuration:
I’ll update the doc (haven’t worked on the repo in a while)
I’m also working on updating the add-on since HA deprecated bluepy
great, ive noticed that mine no longer gets data from the scale since the latest version that brought bluetooth proxy, i dont have any proxies but something must have changed
HA stopped supporting the bluepy library. I’ve been working at using the bleak library instead. I’m close to publishing something in the next few days :slight_smile:
Great to see your being so active with the updates. Implemented and tested them, but cant get it to work anymore. Has anyone tested it over the use of bluetooth proxy on an ESP32?
Just posting an update that a new version is available supporting bleak.
  • Standalone docker container version here
  • HA Add-On version here
Thanks to all early updaters for your help in troubleshooting :hugs:
Also interested in getting it working using bluetooth proxy on an esp32!
I use HA, Passive BLE monitor and BodyMiScale integrations. I have followed the example you provided, but HA informs me that there’s an error in the configuration:
Invalid config for [bodymiscale]: expected a dictionary for dictionary value @ data['bodymiscale']. Got [OrderedDict([('platform', 'template'), ('sensors', OrderedDict([('weight_name_user1', OrderedDict([('friendly name', 'Waga P'), ('value_template', '{% set weight = states(\'sensor.ble_weight_waga\') | float(0) %}\n {% if 74 <= weight <= 90 %}\n {{ states("sensor.ble_weight_waga") }}\n {% else %}\n {{ states("sensor.weight_name_user1") }}\n{% endif %}'), ('unit_of_measurement', 'kg'), ('icon_template', 'mdi:weight-kilogram')]))]))]), OrderedDict([('platform', 'template'), ('.... (See /config/configuration.yaml, line 12).
The configuration itself is as follows:
  sensors:
    weight_name_user1:
      friendly name: "Waga P"
      value_template: >-
        {% set weight = states('sensor.ble_weight_waga') | float(0) %}
          {% else %}
        {% endif %}
      unit_of_measurement: 'kg'
      icon_template: mdi:weight-kilogram
  sensors:
    weight_name_user2:
    friendly name: "Waga E"
    value_template: >-
      {% if 40 <= weight <= 55 %}
      {% else %}
          {{ states("sensor.weight_name_user2") }}
      {% endif %}
  sensors:
    impedance_name_user1:
    friendly name: "Impedancja P"
    value_template: >-
          {{ states("sensor.ble_impedance_waga") }}
      {% else %}
      {% endif %}
  sensors:
    weight_name_user2:
    friendly name: "Impedancja E"
    value_template: >-
      {% else %}
      {% endif %}
What I have missed or did wrong?
Can we identify users with NFC Tag? This means a person first scans the tag before weighing his or her weight.
Have you seen the addon for MiScale yet?
Runs fantastic and also saves the values.
With all other integrations etc. I had after each restart an “unknown” but the addon runs bomb!
Hi, I was able to make my connection without esp32. Thanks @lolouk44.
Would you write a nice interface for Ha. (HA’s own interface is bad)
What do you mean by that?
Custom cart. How can I tell you, it’s just for your plugin. To see body information more visually.
Just a suggestion, thanks again for the plugin.
Sorry I’ve only built the plug-in. For the Lovelace card there’s plenty ways to build what you want. It all depends on what information you want displayed. Have a look on the community there are plenty examples on how to display sensor information
Hello and congratulations for the graphs, can you explain how you made the table with "current weight, change since yesterday, change last 7 days … Thanks
When i install the HA add-on and configure, save and i will start the addon i get this error:
This add-on does not expose configuration for you to mess with…
I dont see anything on the logs.
That error message doesn’t look familiar at all. Are you sure you installed my add-on?
