Integration ARNEN Inverter 10.2KW in Home Assistant via PIPSOLAR
Hello everybody,
I need your help. Let me talking about the situation. I have a ESP32 linking with my Inverter. I can read a lot of sensor but unfortunately I can’t read the PV2 (dual mppt inverter), QPIGS2 return an error.
After discussion with @syssi, please see below the conclusion.
This is the interesting part from the log:
[18:48:31][D][uart_debug:158]: >>> "QPIGS\xB7\xA9\r"
[18:48:31][D][uart_debug:158]: <<< "(000.0 00.0 230.0 50.0 0391 0368 004 423 53.00 000 100 0032 00.1 090.3 00.00 00008 00010110 00 00 00010 0101\xBE\r"
[18:48:32][D][uart_debug:158]: >>> "QPIGS2h-\r"
[18:48:32][D][uart_debug:158]: <<< "(NAKss\r"
QPIGS is the command to request all details about the first MPPT. You can see a proper response here:
The response to QPIGS2 (measurements of the second MPPT) is rejected:
(NAKss\r
In other words: Your inverter doesn’t provide any measurements using the PIP protocol. Please search for other issues of this repository/project. There are a lot of users having the same issue. If I remember correctly some inverter does support more than one protocol and may be you can query some details via Modbus too.
Unfortunately after one week searching on all forums, I can’t find a solution with the integration of PIPSOLAR and MODBUS. I think, I’m not alone in this situation and I will really appreciate your help.
In advance thanks.
Any ideas, how to get data from the second MPPT, not from Arnen but another inverter with the same error ?? really appreciate your help guys…
