hello peter, i am new to the community, but where can i find the link? ![]()
Not sure if the robovac x9 pro is supported. Tried to add it and logged in but couldnāt find any device. How can I help or can you help? Would really like to have this automated after a year ![]()
Hey @jeppesen, thanks so much for integrating the X10 into HA! My wife is loving the fact that I was able to put a āclean this roomā button in each room of the house so she can just send the X10 out to clean that room based on the Room ID.
I was the one reporting back on your github it took me 17 tries before I hit the right MapID btw ![]()
I had started a thread here with a question that you might be able to help out with but I didnāt even know this thread existed. If you mind having a look if THIS would be possible, that would be great!
Thx again for the X10 integration. I always wanted an S1 Pro but the Kickstarter didnāt cover Australia and when it finally got released here it was way too expensive. But having this integration for the X10 while the S1 is still not being supported (as far as Iām aware) makes it all worthwhile ![]()
Also, any idea whether the new Eufy E25/E28 will follow down the path of the X10 or the S1?
When it comes to the non MQTT vacuum cleaners, I need help writing that, or if I had access to a vacuum, I guess someone with decent Python knowledge would need a few hours only to integrate it
When it comes to future models, I have no idea whatsoever. This project started as just a thing for myself and my home. I am just happy so many use it and enjoy it! ![]()
No rush on my account, Iāll be skipping the S1 now anyway
. Happy with my X10 atm even though at a certain point it will be moved upstairs since Iām keen on a self cleaning roller style mop for downstairs.
Plenty of new and interesting models have come out and are planned to come out that offer this now.
Thereās a couple of new innovations that might sway me to a new brand (e.g. the Narwal Flow looks interesting) but HA integration has become crucial and I donāt think anyone has cracked that yet for the Narwals.
Ecovacs looks stronger these days (although I worry about their reliability and obstacle avoidance) and I just discovered that someone created a gobetween called Bumper that negates the need for using their cloud which makes it VERY appealing. Not sure if the latest X8 and X9 Pro Omniās will be supported though.
If the new Eufys end up using the same protocols as the X10 and being supported by your integration as a result they would still be a strong contender as I weigh my options, but in the meantime Iām very happy to enjoy my X10 through HA thx to your integration.
So thx again for sharing something you originally intended for home use, itās incredibly appreciated!
Just to be sure: Can I block the vacuum from internet access or does it call cloud api?
Would this integration work with the X8?
Nice work, after testing lots of things, finally this one works.
I love to contribute to this project
Hello where should I enter this code ?
Iām having a little trouble with building a script to run the action. āExtra keys not allowed @ data[āmap_idā]. Got Noneā
Any idea what Iām doing wrong. Pretty much copied the example vaccum.send_command like for like. Seems to dislike the map id
New HA user here. I added the integration via HACS and got it working. Where do I paste in the scripts to run certain scenes?
Found this thread after buying an X10 and the realising it was not as well integrated as some of the other models.
I just have 1 thing missing from the integration that would make it perfect for me.
The app reports the water level in the tank but it is not shown in this integration. Only had it a few weeks but it did show 0% water but did not actively tell me. only because I am constantly looking at the app (although this will fade as time passes)
Can this be added?
As this is MQTT can I access more data via my broker.
I am struggline to find my map ID. it keep fails to find position
Hi. I am a bit lost. I installed in HACS and added the Integration, logged in⦠but where it says select your vac there are no options to click? Can anyone help? TIA
I was having the same issue. Gave up at the time but with the Alexa skill now not working would be good to sort.
Complete noob to HA and HACs. I have installed HACs and the eufy-clean integration, but Iām completely stuck now. What are the next steps? How do I connect with my eufy x10? How do I log in?
You should be able to do, settings, devices, add integration, choose Eufy MQTT and login with your Eufy account. If you cannot see the integration, you might need another restart as is required after each install from HACS.
@jeppesen - do you have a list of the MQTT Eufy vacuums, noting you would not have tested them all?
I have an X8 and canāt find information on whether it uses MQTT or not.
Thanks for that. I thought Iād added the integration but hadnāt done it right.
I do not think that the X8 is a MQTT one, but i do not have a list. Thereās alternative integrations if it is not a MQTT one I believe
