Home Assistant integration for StormAudio processors
Home Assistant custom component integration for StormAudio, Focal and Bryston processors.
GitHub - Ltek/StormAudio: Home Assistant integration for StormAudio ISP & ISR, Focal Astral 16 and Bryston SP4 · GitHubSupported devices
Integration supports the StormAudio family of processors that use the published TCP/IP API (port 23,
firmware 4.6r1 or later) platform as of August 2026:
- StormAudio ISP and ISR series
- Focal Astral 16
- Bryston SP4
Focal and Bryston branded units share the same API with one documented exception that Front Panel
Color) aren’t available on those brands.
This is the most feature rich, and robust Home Assistant integration for StormAudio.
Entities
media_player- main device control (power, volume, mute, source, sound mode)switch- Mute, Power
- Dim, Dolby Virtualizer, Dialog Norm, Center Spread, LFE Dim
- Per zone: Mute, EQ, Binaural Mode
- Per trigger: on/off
select- Source, Source (Zone 2), Preset
- Dolby Mode, Auro Preset, SphereAudio Effect, Loudness
- DRC, IMAX Mode (on/off/auto)
- Front Panel Color, Front Panel Standby Delay
number- Volume Level
- Center Enhance, Surround Enhance, LFE Enhance, Bass, Treble,
Brightness, LipSync - Auro Strength, Dialog Control
- Front Panel Standby Brightness, Front Panel Active Brightness
- Per zone: Volume, Bass, Treble, LipSync
sensor- Surround Mode (+
engagedattribute), StormXT - Video Resolution, Video Encoding, Video Refresh Rate, Video Input,
Video Sync, Video Copy Protection, Video Color Space, Video Color
Depth, Video Mode (one set per HDMI output - see Notes) - Active Speaker Config, Sample Rate, Stream Type, Channel Format
- Surround Mode (+
Per-zone and per-trigger entities are created dynamically based on what
the StormAudio device reports at startup (its zones.list / trigger.list broadcasts).
If you add or rename zones/triggers on the unit itself, restart the
integration (or Home Assistant) to pick up the change.
The protocol client (stormaudio_telnet/) is vendored directly in
this integration rather than pulled in as a separate pip dependency.
Notes
- Video info is read for every HDMI output listed in
HDMI_OUTPUT_IDS
(stormaudio_telnet/constants.py) - HDMI OUT 1 and OUT 2 by default.
The HDMI OUT 1 sensors are enabled by default. The HDMI OUT 2 sensors (named
... Video Resolution (HDMI OUT 2), etc.) are created disabled;
if your display is on HDMI OUT 2 or you run dual displays, enable the
ones you want from the entity’s settings (Settings → Devices &
Services → StormAudio → entity → gear icon → Enable). No code change or
restart config is needed. If a future unit exposes more than two HDMI
outputs, add the output number toHDMI_OUTPUT_IDSand the client and
sensors pick it up automatically. - Zone sub-controls (mute/bass/treble/eq/binaural mode/lipsync) rely on
the StormAudio device resending its fullzones.listbroadcast whenever any zone
field changes (per the API doc) rather than parsing each zone’s
individual per-field echo separately. - Some controls require licenses/hardware to be present (StormXT,
SphereAudio) - when not licensed, the StormAudio device returnserror, which shows
up asunavailablefor the corresponding sensor/select rather than a
numeric value. - For Bryston/Focal-branded units, Front Panel Color isn’t available;
these devices do not respond to that command so the entity will always show “unknown”.
Installation
Integration is not in the HACS Store.
HACS App (recommended)
- Go to HACS → ⋮ (top-right menu) → Custom repositories.
- Add this repo URL -
https://github.com/Ltek/StormAudio- with
category Integration. - Find StormAudio in the HACS list and click Download.
- Restart Home Assistant (Settings → System → Restart).
- Add the integration: Settings → Devices & Services → Add
Integration → search for StormAudio, then enter your
processor’s host/IP and a name.
Manual
- Copy the integration folder to your Home Assistant config directory so
the files land at:
/config/custom_components/stormaudio/
(i.e./config/custom_components/stormaudio/manifest.json,
.../__init__.py,.../media_player.py,.../stormaudio_telnet/, etc.) - Restart Home Assistant (Settings → System → Restart).
NOTE: restart is required after installing or updating it - a config-entry “Reload” will not pick up new code.
