Integration Geizhals
For some time now, the integration Geizhals (https://www.home-assistant.io/integrations/geizhals/) no longer seems. No matter what I specify as a product id, no sensor is generated.
I get the following error message:
Protokolldetails ( ERROR )
Logger: homeassistant.components.sensor
Source: components/geizhals/sensor.py:97
Integration: Sensor (documentation, issues)
First occurred: 14:08:20 (1 occurrences)
Last logged: 14:08:20
geizhals: Error on device update!
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 319, in _async_add_entity await entity.async_device_update(warning=False) File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 466, in async_device_update self.update # type: ignore File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run result = self.fn(*self.args, **self.kwargs) File “/usr/src/homeassistant/homeassistant/util/init.py”, line 239, in wrapper result = method(*args, **kwargs) File “/usr/src/homeassistant/homeassistant/components/geizhals/sensor.py”, line 97, in update self._device = self._geizhals.parse() File “/usr/local/lib/python3.7/site-packages/geizhals/geizhals.py”, line 78, in parse self.device.name = raw.string.replace(’\n’, ‘’) AttributeError: ‘NoneType’ object has no attribute ‘string’
Does anyone know anything more specific about it or can someone confirm the error ?!
Unfortunately I can confirm the error:
Source: components/geizhals/sensor.py:94
Integration: Sensor ([documentation](https://www.home-assistant.io/integrations/sensor), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+sensor%22))
First occurred: 5:07:59 PM (1 occurrences)
Last logged: 5:07:59 PM
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 357, in _async_add_entity await entity.async_device_update(warning=False) File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 466, in async_device_update await task File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run result = self.fn(*self.args, **self.kwargs) File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 239, in wrapper result = method(*args, **kwargs) File "/usr/src/homeassistant/homeassistant/components/geizhals/sensor.py", line 94, in update self._device = self._geizhals.parse() File "/usr/local/lib/python3.8/site-packages/geizhals/geizhals.py", line 78, in parse self.device.name = raw.string.replace('\n', '') AttributeError: 'NoneType' object has no attribute 'string'
My config:
  - platform: geizhals
    description: AMD Ryzen 9 5950X
    product_id: 2392527
    locale: DE
@bussio Have you found a workaround?
Nvm. I see you created a bug report: https://github.com/home-assistant/core/issues/38123
