Integration of HM-10 to home assistant
Hi, I want to integrate a HM-10 device into home assistant. The HM-10 streams strings over Bluetooth LE. Chatgpt adviced to stream it to mqtt and then over to ha. With help of chatti I built a system with hm10_mqtt.py, which connects to HM-10 and hands over the data to mqtt. I use a raspi5 with ha 18.1. and in the terminal window this works fine, I see the strings. If I configure it as a ‘local app’ with a Dockerfile and a config.yaml the local application stopps with some error.
Howto configure it to work?
Is there an example somewhere with a BTLE device talking to MQTT and Integration in HA.
THX
Cheers
Detlef
