When I started HA for the first time I was sure LightwaveRF showed as an integration and picked up all my switches and sockets. I have since reset HA as I had problem with not being able to toggle the power off to my devices and being new to HA I had no idea of what else to do. Having reset and logged back in LightwaveRF integration is not detected and all the information I can see if to add the integration to the configuration yaml. I have no clue how to do this, so if there is anyone who can guide me that works be great. Before I move onto automation I want to get all of my devices functioning and signed to their rooms. Thanks in advance.
Copy and paste the example from the documentation into your configuration.yaml file and edit it for your particular setup.
It’s a while since I used Lightwave, but it still seems to be a yaml-only integration - I don’t think it’s going to be automatically detected by HA.
However, Lightwave is a 433.92 MHz system and there are other integrations that might pick up Lightwave devices - could you have been using one of those? For example:
